No rear speakers
  • On my just installed X12 in my 17 RAV4 I don't have rear speakers, car does have the factory amp. If I go to balance/ fade and fade to rear all sound is lost. Where do I start to correct this? Could the base settings be default to the non amp version of the car?
  • @CLM Could you please go to Settings>About Device>Bulid Number, and provide version information to us.
  • This is what I see per your instructions, i also see QR codes under device info, does this give you the needed info?
  • @CLM
    Settings>Car Settings>Factory Settings(0000)>Can Settings>Modify>Simple>Toyota
    And please go to the Car info app to adjust the factory amplifier.
  • @Roadanvi Support do not see the car info app but was able to get to the amp settings, was on analog so I tried digital and still no rear speakers, could I have missed or have a poor connection on the wiring harness?
  • @CLM Did you follow the first step?
    If you still can find the amplifier,please take a video demonstrating how you accessed the above settings,so that we could better conirm.
  • Sorry for not including the first step, I got that ok and confirmed set to 13-18 0X0E-00
    wants to only let me attach a photo not a video
    second step as noted before I found amp settings as follows
    settings - factory - basic - power amp settings - choices are none, analog, digital
    did find the car info app by side swipe and it was on its own page not with the othe apps, amp was set to (on), after reboot I cannot find the app again and the Bluetooth will not stay connected even though it is streaming music from my phone (no rear speakers still)
  • Pulled unit back out to check connections, no mating male rca connectors (red/white) as shown in manual(see pic)
    also on the rear speaker connector only the green pins connect to the mating connector, purple do not connect to anything (see pics)
  • Was able to get to the car app, under amp tab this is what is shown, note fade is front 7, can select and change it but won't retain the change, tried both auto sound leveler on or off with no success in retaining the change
