Radio signal is very weak and microphone has a lot of background (engine?) noise.
  • I have the X12 installed in a 2012 Toyota Camry. The radio reception is bad. I have only found 1 station that is not filled with static, and sometimes, it has static. I have checked the antenna plug 3 times to be sure that it is plugged in correctly.
       Also, the microphone has a lot of noise when making calls. You hear what sounds like road noise and engine noise and even squeals on the other end. We have changed the microphone position a couple of times with no change. Can you help, please?
  • Are you sure you're grounded properly?  A quick continuity check will confirm it or not.
  • I thought it was, I will check that tomorrow. Thanks!
  • I checked the ground and I did get continuity. The ground connection was tight. I checked all of the connections again and the radio connection is still poor. I would appreciate any help.
