HS-X12 Series in 5th Gen 4runner brightness control
  • While on dark highways at night the head unit brightness is blinding.
    Can you send out an update inorder to dim the unit to a very very low backlight setting, so that we are not blinded while driving at night on dark highways? Maybe a stealth mode or something. I have already gone into the unit and dimmed every setting as low as possible, including the headlight control to dim the unit and it's still way too bright.
    Thanks,
    Ron
  • I have all of the dark setting put in place and this unit is still to bright at night, I get blinded by the LED light while driving at night.
    Is there a way to turn this unit brightness down even further to be another 50%-75% darker?
  • This does not dim the screen near enough for very dark roads. The screen is way too bright even at it's lowest settings. Please create an update so that we that want it very low for while driving long distances on mountain roads and highways that are vwery dark. a good 50% more ability to turn it down would be a good start.
