Experiencing These Issues After Update?
🔹 Bluetooth not connecting
🔹 Pairing failures or random disconnections
Quick Solution:
Go to Settings > Car Settings > Factory Settings(0000) > ARM Settings > Make sure the BT Type and Baudrate is the same as below.
@Roadanvi Support don't know what to do ,Bluetooth connection doenst work
Want to know if there is any updates available for the roadanvi X12 .....apparently the last one was 2012 ?
@Ben Jaz
Dear Ben,
Could you please go to Settings>About Device>Bulid Number, and provide version information to us.
I'm having trouble with my Bluetooth connection. At first it was just dropping out during calls. 2 days ago it took a very long time to connect at all. Today, my phone does not detect any Bluetooth signal coming from the head unit.
@Douglas Thomas
Here is my current firmware. I have an issue where the carplay will constantly be trying to connect to my phone but it won't work. So I go to try to remvoe my phone from the systems bluetooth as a kind of soft reset and I can't remove it. I have to keep going into factory settings and changing the settings and/or doing a whole reset every time. This happens every month or so. I have had this one for a year now.
Also, is there anyway I can override the bluetooth for the carplay when this happens and just use a usb cord for direct carplay? When I plug it in, it doesn't work.
@John Maas
Hello,
Thank you for your contact.
Please try to update the system.
