Climate control popup
  • Is there a way to prevent the climate control slider from popping up at the bottom of the screen? With the physical controls under the display, I do not need this information. Whenever the settings change it slides up and I can't seem to navigate around it until it decides to slide back down. I have also seen this slide up at random times and it seems to get in the way.
  • Hi Gregory,
    Do you mean you want to turn off the air conditional info display?
    Could you please send a video of showing the issue that your mentioned?So that we could better confirm,here is the official support team email:
    office@roadanvi.com
  • Hello.
    Disable the following option
    1- Setting.
    2- Car Settings
    3- Factory Setting.
    4- passcode "0000".
    5- CAN Setting.
    6- Makes sure option "Air switch" is disabled.
    7- Reboot.
  • @Samuel Gonzalez
    Thank you for your solution.
    @Gregory Carpenter yes,if you want to turn off the air conditional info,please go that setting:
    Settings>Car Settings>Factory Settings(0000)> Can Setting > Air switch
  • @Samuel Gonzalez Thank you!
