Steering Wheel Key Study on HS-X12 stereo
  • Wheel Key Study
    For head units with a Canbus box.
    Go to Factory Setting > Can Setting > Choose your corresponding Canbus Option. The default setting is based on your head unit's model. If your head unit is functioning properly, there's no need to change this.
    For head units without a Canbus box. You'll need to set the steering wheel keys manually.
    1.Go to the Car Setting > Steering Wheel Setting.
    2.Click on the function on the stereo and then press the corresponding button on the steering wheel to learn.
    3.Click the RESET button to re-learn.
  • My Roadanvi headunit doesn't show car steering wheel setting completely. I'm attaching a screenshot and video. Kindly help me.
  • @Baljinder Singh Sidhu
    For your information, it needs you to press the button on the steering wheel firstly, then it will show corresponding function to select on the headunit.
    If no luck, please provide the following information:
    1.
    Order Number & Purchase Date.
    2.
    Picture: Settings > About device > Build number(MCU, APP).
  • Hi, I've purchased it on Amazon on 15/Nov/2025 amd delivered to my address on 18th. Order number: 111-8325285-5513832.
    And I've tried the way you told, but is not working. Also, I want to know if the headunit has the functionality to fast forward the song or not because only i can find is change to next or previous song but not fast forward or backwards. And I have installed the youtube app on headunit but i don't see the icon, for that i have to go to settings, apps and then i can open youtube.
    I'm adding the photo you asked to share for the information.
    Please try to do the update firstly.
    Update File:
    X12d(20250725):
    https://www.dropbox.com/scl/fi/iqa7i3skojavg2b3jb2ji/ZQ_A107-12_C58_HA11_U459-EN-D_2025-07-25-1450.zip?rlkey=25cm7nqd19pqdraz83w79zvtd&dl=0
    Tips:
    1.
    Format USB drive to FAT32 Format via your computer/laptop.
    2.
    Download above update file and copy it to the root directory of USB drive.
    3.
    Connect the USB drive with the named USB cable.
    4.
    Tick both “Clear all memory data and format!” and “Force upgrade” options then confirm “INSTALLATION”.
    5.
    Wait about 5 mins and you will see the screen turn Green,
    then you can disconnect the USB drive and wait for update successfully.
    Then please go Settings > Steering wheel to reprogram the steering wheel controls buttons to see how it goes.
    And please go Settings > More > Factory Setting(password: 0000) > APP > YouTube > On.
    If you need further help, please feel free to contact us via email.
    📩Email: office@roadanvi.com
